Update on Mach-E launch progress from engineering friends in Mexico
dbsb3233
TimCO
Colorado, USA
Economically, the EU is also the first world's largest market at around 445 million people. Compare that to the USA's population of 330 million or so.
More population, but actually total car ownership is about the same between the US and Europe. The US is more car-centric. Especially our cities which tend to be newer and largely designed for the automobile-era (as opposed to most European cities that often date back to medieval times).
eager2own
Southlake, TX
Or one could say because our cities do not have proper intra- or inter-city public transportation like EU cities and, therefore, a family of four requires four vehicles in the U.S.
dbsb3233
TimCO
Colorado, USA
In part. But as another poster put it yesterday, cars offer more freedom too (and flexibility). Pros and cons to both.
The population for the entire Eurozone adds another 100 million or so onto the EU "proper") numbers. The Eurozone + the UK (For the remainder of this year only) is the EU market. GDP wise (minus the UK) it's about equivalent to the US.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Probably because Ford, along with all other manufacturers will get hefty fines this year and next if they fail (most will) to get their co2 emissions down. The sooner the MME lands in UK/EUR the average emissions for Ford will reduce making the fines less
And we thank you for your governments push. Us over here are a bit thick and slower it appears; you will need to bear with us. ?
ClaudeMach-E
Claude
Quebec Canada
Yes but they sale more EV over there too.
ARK
Los Angeles
'21 Premium SR AWD
I know nothing about automotive production scheduling, but I’m guessing they want to minimize production line changes and maximize initial profits, so with that, I’m selfishly hoping production is sequenced:
First Editions
Premium ER AWD
Premium ER
CA Rte 1
Premium SR AWD
Premium SR
Select ER AWD
Select SR AWD
Select ER
Select SR
who knows? Maybe they just come into the factory each day and draw build sheets at random out of a pile, or look at whatever parts are laying around?
I do hope the Premium SR AWD’s come before the Premium ER RWD’s, hoping to get mine delivered this year to get the federal tax credit sooner rather than later.
Side note, there actually are no extended range Select trim MME’s.
AndyS_OSU
Texas
2017 Chevrolet BoltEV
Educator
I hope you’re wrong and Premier standard range RWD get built first for exactly the same reasons. Also maybe they should go mostly by order number as much as possible.
MerryBrown
Mary
Northern, CA
2018 Ford Escape, Red Ford Mach-E on order
Finance
For efficiency reasons won't they make similar cars for a stretch and then another type for a bit? It would seem if they are trying to move the line as fast as possible they would make all the premium RWD, then Premium AWD then move to another style? I think I have seen @ChasingCoral and @trutolife27 discuss it that way.
JCHLi
Think about it like this: 2 shifts and 150 cars a shift. Even if they only did change overs between shifts, the impact of batched runs will have a much smaller impact compared to the real factor which is reservation number.
ARK
Los Angeles
'21 Premium SR AWD
Making a bunch of the same trim makes the most sense to me. But another consideration would seem to be shipping. Would they want a mix of multiple trims to include in a shipment to a region so they don’t keep making single car shipments to a dealership (aside from the mega dealers)? Or maybe it doesn’t matter because the Mexico plant makes a bunch of other types of Fords anyway so no issue with making sure the trains are fully loaded?
I have no idea, just speculating over here. But if I were to guess, I’d say they probably will rotate through the trims every day/week/some other logical dividing point, so that they don’t make 20,000 premiums before a single select rolls of the line. Exception would probably be the FE, seems they should make all of the FEs first.
zhackwyatt
I'm fairly confident that is not how it works. They build extended cab, crew cab, and regular cab F-150's all intermixed.
In fact the C-Max was built on the same line at the same time as the Focus and Focus electric. There may be general groupings due to part shortages, but they will definately be intermixed too.
