- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat
Read your warranty.Hi Rick,
Thanks for your contribution. Maybe 15 percent less range is not a significant number to you. I don’t wish to split hairs on what constitutes “significant”.
As for the battery capacity measurement, I would assume the GOM would have nothing to do with it.
Are we speaking of kw measured via a car scanner app at full charge? Because you are staying the stale of health isn’t the measurement to judge this. Sorry for the ignorance
High Voltage Lithium-Ion Battery Capacity Coverage
As is the case with all batteries, the high voltage lithium-ion
battery capacity will decrease over time and with use. While
gradual capacity loss with time and use is considered normal
wear and tear, Ford Motor Company warrants the high voltage
battery against excessive capacity loss for a period of
8 years/100,000 miles, whichever comes first. If an authorized
EV Certified Ford Dealer determines that the battery capacity is
less than 70 percent of the high voltage battery’s beginning of life
capacity, or less than 65 percent for vehicles in cutaway or
chassis cab configuration, this level of capacity loss is considered
excessive. The measurement method used to determine the high
voltage battery capacity, and the decision of whether to repair,
replace, or provide reconditioned or remanufactured parts, and
the condition of any such replaced, reconditioned or
remanufactured parts, are at the sole discretion of Ford Motor
Company. During the High Voltage Battery Capacity Coverage
period, Ford Motor Company will cover the necessary component
repair or replacement to correct this excessive capacity loss,
when performed by an EV Certified Ford dealership. This
coverage is in addition to the high voltage battery assembly’s
limited warranty for defects in materials or workmanship. If a
warranty repair requires replacement of the high voltage battery
assembly, or one of its components, it may be replaced with a
new, factory remanufactured, or factory refurbished component,
at Ford’s discretion. Refurbished battery components selected
for your vehicle will align with your vehicle’s age, and mileage.
NOTE: The battery capacity degradation rate will vary based on
various factors, including environmental conditions, and will also
be affected by the way in which the vehicle is used. Following the
recommendations in the Preserving Your High Voltage Battery
section of the Owner’s Manual may help lower the rate of
capacity degradation and optimize battery life.
