3/14/22 Build Week Gang
Av8tor
Kevin
Richmond, VA
Fusion Hybrid, MME GTPE
Systems Engineer IOT
For anyone who has anxiety about being bumped--I'm a 3/7 groupmate and my window sticker didn't populate until 3/7 (although it was dated 3/5). My batch is 4645 which is towards the end of this week so whoever has a close batch number will be first in line next week.
Thanks for that info, will help with my anxiety!
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
Same here....seems a bump coming up. This purchase has tested my patience to the limite. Ordered in July and still in this mess.
Me four...and May order. Doing okay on patience. Good things come...
avinator
Avinash
Chicago,IL
Ford Fusion Energi,Mach E,Honda Pilot
I think this patience is testing me so much that i might get nirvana before this vehicle. But with all that's going around in the world put into perspective it's nothing.
mdpmdp
'22 Premium RWD SR Grabber Blue
I hadn't really paid attention to the whole batch numbering thing, seemed like conjecture but I guess it is sequential? We had @pnrmurph report 004647 early in the day yesterday and I received 004675 later that night.
Av8tor
Kevin
Richmond, VA
check this morning at 7:00 no sticker, check at 8:00 am WINDOW STICKER!
004703 299/330
Av8tor
Kevin
Richmond, VA
So, is there a way to figure out the actual build day for next week based of these numbers? 004703 299/330
mdpmdp
I don't think so, but the batch number should tell you approximately where in the week you are. We know now that the range goes from 004647 to 004703, with the 3/7 build week going to at least 004645. Assuming no slips, I would guess that means 004647 should be the first day of build (Monday?). I haven't looked at the ranges of previous weeks yet, but I'll do a quick look in a bit and see how wide their ranges are.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
Your insight is helpful because I am befuddled by the codes and batch number references. Keep explaining because I’m sure it helps others as well as me who are challenged by this tracking system.
Av8tor
Kevin
Richmond, VA
So reading other build threads it looks like
Batch #
(sequence/Total Batch build)
Ford Mustang Mach-E 3/14/22 Build Week Gang 1646930326348
So, I would be in Batch 004703, car 299 out of 330
So I think we have to collect batch numbers like @mdpmdp to figure out A) how Many, B) align to a day based on daily capacity.
Av8tor
Kevin
Richmond, VA
Batch #
Also keep track on when you got your window sticker. Some think that they are generated 1 week out. That might land me on Thursday
Window Sticker: 03/10/22 004703 - 299/330
Av8tor
Kevin
Richmond, VA
I think I got most of the information highlighted.
Ford Mustang Mach-E 3/14/22 Build Week Gang 1647004493869
[Edit 1] Added yearly sequence number, Window sticker print date
[Edit 2] Added unique part of VIN
[Edit 3] Added coded invoice date, changed Invoice Number, changed middle number I thought was sequence to unknown
Av8tor
Kevin
Richmond, VA
For what it is worth:
Special Order box- "03 07 22"
Bottom of the sticker- "03/08/2022"
Batch- 004647
Sequence- 266/300
I think the Special Order Box is the Invoice Date, or Date sent to manufacturing
The bottom of the sticker is the sticker window date initially , and then it starts to change at different milestones. So it will change several times throughout next week.
Av8tor
Kevin
Richmond, VA
By the way, the invisible text - Sold to the dealer that ordered it, Not really sure why, wondering if that changes during the window sticker update. I extracted mine by selecting the text there, pasting it into a note, which reviled the text.
I'm thinking it shows on the actual car sticker.
mdpmdp
Based on what I've seen in other build weeks (and my own sticker), this date randomly updates, it doesn't appear to be tied to any milestone. In my case, the date has already updated to 3/10/2022 today (was still 3/8/2022 yesterday) despite no changes.
Av8tor
Kevin
Richmond, VA
@pnrmurph and @keveburd What is the number after your CUA-? Top Lefthand side of your window sticker?
Im thinking that number is the sequence by year. Since you both are in the same batch, if we take @pnrmurph minus @keveburd we should see 273, that would confirm that's the yearly sequence number.
again, @keveburd will confirm this hypothesis @Av8tor CUA-005875 @pnrmurph CUA-005006, I'm thinking that there are 869 mach-e between you and me.
[EDIT] for those that read this later. The CUA-XXXXXX is an invoice number, but it is not in sequence unless you were invoice that day. I removed it from the listing on Page 8, because it is irrelevant for tracking builds.
