phidauex
- Sam
- Dec 8, 2020
- Colorado
- 2021 MachE 4EX, 2006 Prius, 1997 Tacoma
- Renewable Energy Engineer
Installed the 10" JL Audio PowerWedge+ last night, thanks for all the details in this thread, things went pretty well, and it does sound great. The fit is just about perfect. I bought a "scratch and dent" model from Crutchfield for some nice cost savings. I think it maybe had a tiny bump on the grill, but I probably did worse just taking it out of the bag.
A few notes from my install:
- I tapped into the 12V accessory outlet power above the stock subwoofer. I know it is only fused at 20A, and I'll probably run a real power cable later, but I wanted to get rolling and I don't run at high volumes. Not officially recommended. I did reduce the amp's internal fuse to 20A, if I blow it then at least I protected the cables and hopefully it blows before the main fuse for the 12V circuit blows.
- For making connections I used my favorite new little connectors. These are heat shrink tubes with low-temp solder built in. You just stick the two ends of the wire in, use a heatgun to shrink the outer parts of the tube to hold onto the wires, then hit the middle part, the solder melts and flows, and you have a nice clean soldered and sealed connection in one shot. I use a small butane Dremel-branded micro heatgun to get into tight spaces. https://www.amazon.com/Shrink-Solder-Sleeve-Crimpless-Connectors/dp/B01H7MU8W8?th=1
- Be careful and keep the car fully shut off while working on the wiring. I was a dork and cut my + and - power cables at the same time while aux power was on, so I blew one of the fuses in the main fuse box (fuse number 61 or 71, a 20A MCASE slotted cartridge fuse - I did find that a nonslotted worked as well). The main fuse box is a massive pain to get into so be extra careful and don't be silly when cutting wires. These fuses aren't available at most auto parts stores and you need to remove the entire frunk to get to the fuse box where they are located. I spent as much time dealing with my little f-up than I did on the entire rest of the install.
- I ran the remote volume control along the driver side of the car, tucked into the plastic trim alongside the carpet. It was fairly easy to fish by hand. I brought it up under the driver seat, and used a bit of 3M VHB tape to secure it. I can reach it easily but it is hidden out of the way and easy to remove.
