Fordpass Android power drain -maddenly inconsistent
Skip Towne
New Hampshire
Mach-E 4x Premium
I posted in another thread that I though the recent update to Fordpass 3.35.2 on android solved the power drain problem. As it turn out - that statement is right some days and wrong other daysI Can you help me know why? (I have that same randomly right/wrong problem talking to my wife, but I don't expect this forum can help fix that)
Some days fordpass will have virtually no drain on my phone while running in the background. Other days it will turn my phone into a handwarmer, using 2-3% battery per hour running in the background and/or overloading the phone's processor (28% of CPU while in the background!)
I've tried, but cannot find a repeatable pattern of my behavior/use that triggers the overload problems. sometime it happens after merely walking near the MME with my phone, but not the FOB in my pocket. Sometimes it happens after using PaaK. But othertimes those same actions have no impact on phone battery use. And when Fordpass is in high-power use mode, restarting my phone will sometimes stop the overload, other times the overload starts again right after the phone restart.
I'm using a Samsung S10 on android 11.
Is there a pattern to this that I'm not seeing? Is there something to avoid doing if I don't want to kill my phone battery (besides using fordpass on my phone)?
dliunatic
Dallas, Texas
I have a S10+ and am seeing the same thing. Can't tell a pattern other than it getting worse these last couple weeks.
skiingj
Roseville, California
Mach-E Premium
S21 Ultra (12) and for the first time in six months of MME ownership started to experience this problem this week. I'm about to remove Paak again and not go back until it becomes reliable (if ever). Paak has been a POS this week. Not sure if that will solve my battery drain issue but I'm feed up with Paak.
It is happening to me also, exactly as you described. There are no location or power restrictions on the app, as required. Note 9, FP 3.35.2.
imstriker
Matthew
Indianapolis
Tech
Mine has gone haywire the last week or so. It was great. No reboot, etc helps it.
Ford Mustang Mach-E Fordpass Android power drain -maddenly inconsistent Screenshot_20211230-161553
I'm sure I'll get lambasted for saying this, but I have never had a problem with FP draining my battery because I don't use PaaK.
Just thought I'd mention it
noway
Norway
2021 Mach-E First Edition
Software developer
I have found a pattern in that it is possibly likely to appear when and after the phone has had a bad network connection
Electric Goat
Twin Cities, MN
'21 Mach-E GT & '24 BRZ
I've been running FordPass with the following configuration since Day 1:
Settings >> App >> FordPass >> Battery >> Restricted
My phone consistently reports "0% battery usage since last fully charged".
Power draw problem solved... I don't have PAAK set up yet.
If that time comes then I'll probably just have to open up the app if I want to authorize it to talk to the car.
I'm running a Galaxy S21 on Android 12
skiingj
Mach-E Premium
The last few weeks FP has drained my battery every couple days even when it's closed.
I've checked and rechecked settings, reset Paak 5-6 times to no avail.
I'm going back to the one fob and removing FP and re-installing so Paak is disabled.
Electric Goat
Twin Cities, MN
Which is why you don't see the battery drain.
So I went ahead and set up PAAK. FordPass continues to draw 0% battery throughout the day. :cool:
To prevent battery drain, as stated above, go to your phone settings under:
PAAK will now only connect after I manually open the app. I'm happy with this solution since I prefer using the keyfob. I love that I can now use PAAK as a backup or if I want to open the front trunk or roll down the windows remotely.
Different Android phones, different settings. On mine it is AppInfo -> FordPass -> Battery -> Optimize.
I am not sure if this will help or not, but since I gave up on PaaK, now I am just trying to keep the app from killing my battery, same as you. The app does not kill the battery every day, and I am not sure what sets it off. I can go days without any issue, and then wham! Battery killed.
skiingj
Mach-E Premium
I like this idea. Just to clarify in this mode Paak with not function at all unless the app is open?
Electric Goat
Twin Cities, MN
Correct. PAAK now only works after I manually open the app. Once I completely close out of the app (including not running in the background) then PAAK ceases to function.
It might also be important to note that I'm running Android version 12.
skiingj
Mach-E Premium
Cool. Thanks for the info. I'm on 12 too.
