FORScan MME spreadsheet
DevSecNetOps, General PITA
Any chance someone has a decoder ring and could tell me if there is a steering wheel weight adjustment? Wife finds it too stiff, and honestly I'd like it a little lighter.
Neil4Real
This is also fun...the Auto high beam ramp up that the later 22s and 23s have. Got it working on my early 22.
734-01-01 xxxx xxx1 xx--
734-01-04 00BC 1612 <-have to change your value to match this, or you'll get a headlight system error.
Tried it out and it works perfect. I have no idea what it'll do on a '21. But you must have a higher trim with the LED Projectors, otherwise there isn't a headlamp control module (HCM).
I have a 2021 Job 2 and this didn't work for me. Just to confirm, I went to the HCM as-built and modified only the line "734-01-04 XXXX" to match yours, adding 00BC and 1612.
It gave me a HCM DTC that stayed after clearing. Bummer!
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
Other Ford's have an SECM, Steering Effort Control Module (7C5), but I don't see it in the list of my Mache-E modules. Looking at the F-150 SECM module, nothing pops out as an obvious setting anyway.
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force (ret.)
Dang. Must be something to do with the software on that year.
ksroskel
Keith
Meridian, Idaho
2023 Mach-e GTPE, 2022 F105 SuperCrew LWB Hybrid
Electronic Design Engineer
On my 2022 F150 I can have the taillights on when the DRLs are on. Does anyone know how to do this on the Mach-e? In the BCM module I see 726-06-03 and 726-06-04 have DRL settings but no description as to the function.
LaFong
LaFong
Colorado
Systems Engineer
Looks like it’s 726-11-04 (DRLIPC ENABLE)
Ford Mustang Mach-E FORScan MME spreadsheet 1675015176575
JSeis
AWD Select
Our April ‘21 build of a SR Select had a menu screen that showed folding mirrors which I promptly turned on. Our car sheet showed heated mirrors but not folding heated mirrors so.. then an OTA update fall of ‘21 possibly winter of ‘21-‘22 resulted in that feature “disappeared” from the menu (as was “intelligent” driving mode and likely other choices I’d no clue about). The mirrors folded perfectly so actuators are there. Probably the bin of heated mirrors was empty so we got the “unofficial supply chain squeeze upgrade” ?!
Our dealer rep suggested that it’s probably possible to turn the folding mirrors back on though I’m ok just leaving well enough alone. He did mention… “Forscan” expert could probably help…
21st Century Pony
Martin
Arlington, Virginia
There is a DIY thread on how to do this. It's really simple to do.
ksroskel
Keith
Meridian, Idaho
I am running Forscan 2.3.50, which I believe is the latest release. when I try to connect to my 2023 GTPE I get the message that the vehicle cannot be identified and asks me to input the part number of the factory PCM. Has anyone been able to use Forscan on a 2023?
LaFong
LaFong
Colorado
Systems Engineer
I have a 2023 and got that error. I asked the Forscan folks and they sent me a link to version 2.3.51.test20221222, which works
Formanrobs56
Rob
Lewes, DE
2023 Mach E GT
Semi-retired ( PT bartender and live sound engineer)
Yes. You need 2.3.51. It is in pre-release and supports 2023 model year MME.
ksroskel
Keith
Meridian, Idaho
Thank you Rob, I worked with FORScan and got a test version of 2.3.51 that worked with my 2023 GTPE
Neil, I have a 2021 Job 2 and it works perfect. You need to change TWO lines in the HCM
734-01-01 xxxx xxx1 xx-- Change the last digit in the second set to "1"
734-01-04 00BC 1612 Change both the first and second sets of digits to "00BC 1612"
