installing 240V Plug
Just finished reading that article. You beat me to it.
horsiedad
North Atlanta
Ford Mach-E GT PE, Mach-E Premium
I had a 14-50 outlet installed a month ago and total cost to install was under $250. It was inexpensive because the distribution box is in the garage and the outlet was mounted within 6 ft of the box. I used 6 gauge copper, capable to supply a 60 Amp Level 2 charging system but fused the circuit now for 40 Amp to use the included Ford Mobil Charger. I anticipate this will be completely adequate for my needs but if not, I'll buy a Level 2 system and change the breaker.
How many conductors did you need for your 6 gauge wire? 3 + ground?
