Mach-e dead again
DYohn
Valley of the Sun
2021 Mach E Premium Ex
12V batteries fail and it seems they fail more often in electric vehicles. Indeed it was the only thing that ever failed in my wife's Chevy Volt. We had to replace it for shorted cells every 8 or 9 months like clockwork. Thank the gods for Costco's no questions replacement program.
Shayne
Shayne
Northern Ontario Canada
2021 MME4x Prem
Saturday morning -30C (-15F) woke up to a charging fault so went out to check it as that is the sign.
Unplugged, started and errors
Service AdvanceTrac
AWD Off
Service Vehicle Soon
Pre-Collision Assist not available
Stop safely now
Vehicle will not go in gear.
When I plug 240V back in get all red port lights.
Car dead again. 12V dead again and brand new. Bad 12 V appears to be not the problem. Third time is the charm and need it fixed this time.
Should put the 12V charger on it. Does anyone know if it can be too cold to charge a 12V (damage)?
Ford Mustang Mach-E Mach-e dead again IMG_3554
Ford Motor Company
Official Ford Account
Service AdvanceTrac
AWD Off
Stop safely now
Hey there. I'd like to look into this battery concern on my end. Can you please send over a private message with your VIN and the name and location of your local Ford dealer?
Shayne
Shayne
2021 MME4x Prem
Done; need all the great minds I can get at this stage to please fix this glitch for me. It was noted that the car was drawing power from the 240V charger (not charging) out of schedule for over an hour yesterday evening and then the 12V was dead this morning. Some state triggers it.
louibluey
FE "Louibluey" GB
Service AdvanceTrac
AWD Off
Stop safely now
@Shayne Sorry to hear, we feel your pain. It must be okay to charge the LVB to at least -30F, otherwise the car would be unusable in northern locations. That said if your charger has settings, you could start easy, maybe 10A to 20A, but even that should not matter.
We have been much warmer than normal in upstate, NY, although some chilly days are starting to happen now. We can go down to -25F at least a few times a year, which I thought was unusually cold for the U.S., but when I did some googling, a lot of locations in the US can go that low in winter from NW through the midwest to Maine. MME must work normally down to -30F, or a lot of us are going to have trouble.
Keep posting, and tell us how it goes.
I can tell you that at least one of the early demos Ford was driving around last year had a 12V battery minder cable showing in the frunk, but we thought they solved this 12V LVB problem last spring/summer through software updates.
Shayne
Shayne
2021 MME4x Prem
Thankyou for the info the charger started at save (snowflake) and then swithed to charge 4 amp.
It is alive again with a 12V charger and then fired up and charged itself to 82%. Left it running (started) until it got over 80% where it dropped to 1 amp. It is even showing puddle lights tonight so it must know it misbehaved. ;)
Wondering if the first error code may have something to do with it?
Code:
Car Scanner ELM OBD2
DTC report
Selected brand: Ford
VIN: 3FMTK3SU6MMAXXXX
============1==============
P0AA2
Raw code: 0AA2
ECU: 7EC
Status: Confirmed
OBDII: Hybrid battery positive contactor - circuit stuck open
============2==============
U0594
Raw code: C594
ECU: 7EC
Status: Confirmed
OBDII: Invalid data received from hybrid powertrain control module
============3==============
U3513(00)
Raw code: F51300
ECU: 7EC
Status: Pending, Confirmed, Test failed since last DTC clear
============4==============
U3517(00)
Raw code: F51700
ECU: 7EC
============5==============
P0AA2(00)
Raw code: 0AA200
ECU: 7EC
Status: Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============6==============
U0594(00)
Raw code: C59400
ECU: 7EC
============7==============
P0D2D(00)
Raw code: 0D2D00
ECU: 7EE
============8==============
P1A07(00)
Raw code: 1A0700
ECU: 7EE
Ford: INVERTER HIGH VOLTAGE PERFORMANCE
============9==============
P1A10(00)
Raw code: 1A1000
ECU: 7EE
Ford: HYBRID POWERTRAIN CONTROL MODULE - BATTERY DISABLED
============327==============
U0594(00)
Raw code: C59400
ECU: ABS/ESP
============328==============
U0151(00)
Raw code: C15100
ECU: ABS/ESP[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
OBDII: Data bus, supplementary restraint system (SRS) control module - no communication
============329==============
U3513(00)
Raw code: F51300
ECU: BECM
============330==============
U3517(00)
Raw code: F51700
ECU: BECM
============331==============
P0AA2(00)
Raw code: 0AA200
ECU: BECM
============332==============
U0594(00)
Raw code: C59400
ECU: BECM
============336==============
U0293(00)
Raw code: C29300
ECU: DCDC[Archive (inactive)]
OBDII: Lost communication with hybrid powertrain control module
============337==============
U2404(92)
Raw code: E40492
ECU: GWM
Status: Test failed (current drive cycle), Confirmed
============338==============
C1001(54)
Raw code: 500154
ECU: IPMA[Archive (inactive)]
Status: Test failed since last DTC clear
============339==============
U2100(00)
Raw code: E10000
OBDII: CAN-BUS Communication Malfunction
============340==============
U3000(49)
Raw code: F00049
OBDII: Control module
============341==============
U0415(86)
Raw code: C41586
OBDII: Invalid data received - anti-lock brake system (ABS) control module
============342==============
B1578(78)
Raw code: 957878
Ford: Lamp Park Input Circuit Short To Ground
============343==============
P0D2D(00)
Raw code: 0D2D00
ECU: SOBDMC
============344==============
P1A07(00)
Raw code: 1A0700
ECU: SOBDMC
============345==============
P1A10(00)
Raw code: 1A1000
ECU: SOBDMC
============346==============
P2DA7(00)
Raw code: 2DA700
ECU: SOBDMC
============347==============
U351B(00)
Raw code: F51B00
ECU: SOBDMC
============348==============
U351F(00)
Raw code: F51F00
ECU: SOBDMC
louibluey
FE "Louibluey" GB
Code:
DTC report
P0AA2
Raw code: 0AA2
ECU: 7EC
Status: Confirmed
U0594
Raw code: C594
ECU: 7EC
Status: Confirmed
U3513(00)
Raw code: F51300
ECU: 7EC
U3517(00)
Raw code: F51700
ECU: 7EC
P0AA2(00)
Raw code: 0AA200
ECU: 7EC
U0594(00)
Raw code: C59400
ECU: 7EC
P0D2D(00)
Raw code: 0D2D00
ECU: 7EE
P1A07(00)
Raw code: 1A0700
ECU: 7EE
P1A10(00)
Raw code: 1A1000
ECU: 7EE
U0594(00)
Raw code: C59400
ECU: ABS/ESP
U0151(00)
Raw code: C15100
U3513(00)
Raw code: F51300
ECU: BECM
U3517(00)
Raw code: F51700
ECU: BECM
P0AA2(00)
Raw code: 0AA200
ECU: BECM
U0594(00)
Raw code: C59400
ECU: BECM
U0293(00)
Raw code: C29300
U2404(92)
Raw code: E40492
ECU: GWM
C1001(54)
Raw code: 500154
U2100(00)
Raw code: E10000
U3000(49)
Raw code: F00049
U0415(86)
Raw code: C41586
B1578(78)
Raw code: 957878
P0D2D(00)
Raw code: 0D2D00
ECU: SOBDMC
P1A07(00)
Raw code: 1A0700
ECU: SOBDMC
P1A10(00)
Raw code: 1A1000
ECU: SOBDMC
P2DA7(00)
Raw code: 2DA700
ECU: SOBDMC
U351B(00)
Raw code: F51B00
ECU: SOBDMC
U351F(00)
Raw code: F51F00
ECU: SOBDMC
That sounds like it might do it (hv circuit stuck open). If the hv contactor cannot close, the DC/DC converter cannot come on to maintain the LVB.
Shayne
Shayne
2021 MME4x Prem
Where is the lever to close it ;). I guess if it still does not close it will do it again. Have no idea if it is intermittent or stuck for good.
louibluey
FE "Louibluey" GB
Drive over some bumpy roads! I think you are just going to have monitor it until a dealer can have a look. Maybe search the forum for hv contactor or similar, I vaguely remember someone having one changed.
Astraea
MMe Premium AWD ER
Hey! I think I might be having the same issues as you! 12v dead Monday night, took a while bit able to finally get it jumped after calling ford roadside. Happened again tonight. Couldn't get it jumped, got it to a dealership on a flat bed and magically not dead anymore? No idea what's happening and scared to drive it. It was just at the dealership Thursday and they said everything was fine. Clearly not I'd say...:(
Crilly
Dale
Hartland, Wi
Loose connection some where.
Shayne
Shayne
2021 MME4x Prem
Sunday morning it came on for 10:45 AM departure about an hour early. When I got in the 12V was at 97% 13.2V. Drove it 22% and drove great as usual. That night it started to charge at 10 PM as scheduled. ?‍♂
Monday it came on and drew power 5:00 AM "preparing for drive". The 12 V killer appears to be triggered randomly which is not all bad if you have a code system that says Hybrid battery positive contactor - circuit stuck open.
@TheVirtualTim similar problem to the one that was fixed with software last February that effected us? Could it be contacts that kill the first 12V and now is working on the second one? Two times in the three it happened at an ambient temp of around -18F. The other @ around 14F and first time it dropped. All times below 32 (CND 0). Worked well thru the summer but cold has a way of bringing problems to the forefront.
Ford Motor Company
Hi there! This doesn't sound like an experience we want you to have with your Mach-E. Could you please send us a PM with your VIN and the name location of your Ford dealer? I'd be happy to see how I can assist you with this concern.
Astraea
MMe Premium AWD ER
Thank you, sending now.
Shayne
Shayne
2021 MME4x Prem
Good morning, Shayne, thanks for getting back to me! Since you are reaching out to us from Canada, we suggest reaching out to our friends at Ford Canada for assistance. They will have the resources needed to ensure your battery issue is being properly taken care of. You can contact Ford Canada by phone here: 1-800-565-3673 or through Facebook and Twitter here: Facebook.com/FordCanada & Twitter.com/FordCanada .
Drew
Ford Social Media Team
This the the help PM I received ?. Thanks great will get right on that. I will talk to my dealer and will not be phoning a 1-800 tier 1 support line. Too funny. Wondered what happens with all these PM's now I know.
