prdude
pleasant ridge, MI
engineer
this video gives a pretty good explanation of a/c systems in general. My only comment would be that I believe the electronic valve on the chiller's TXV is just a shutoff valve; the TXV opening is still passively controlled.
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
Interesting in that Ford is taking a more conventional approach at this time. They are using a design that has been their bread and butter for a while and adapting to the BEV model. I wonder what the changes will be over the next few years - do they go the heat pump route or stay with a condenser and traditional AC model.
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
Anything what could explain why the charging is so loud with 3 phases and 16A (germany)?
Bad cooling of ac/dc converter?
MG101
RI
a car
They keep talking about the liquid cooled condenser needing less components but where is that liquid getting cooled? There has to be some sort of heat exchanger somewhere that, unless I missed it, never gets mentioned.
Chuck
Chuck
SoCal
Mustang Mach E 2021
Going with what they know reduces the variables needed to hit the ground running. This lets them concentrate on what has to be done differently for an EV. I believe that for Ford's first all EV car this has been a very good job so far. Yes, there have been some software glitches but they'll get those worked out.
The reality is that because it's Ford's first EV and they called it a Mustang this car will be scrutinized ad nauseum and every little flaw will be amplified tremendously making it seem like it's just failing when it's not.
db4z
TX
Focus RS
The radiator they didn't show.
ODBMongoose
Niels
Netherlands
SR RWD Mach-E Star White Tech Pack Plus
See the topic 'insane charging noise' in charging section. Ford already responded to this
Jimmy2
Jimmy
Wilmington NC
Interesting to learn how the cooling and heating systems work in the Mustang Mach-E. I'm not an engineer, but I can add some important observations as the owner of an MME in the south: That AC system cools down the inside on hot summer day real nice and quick, best AC in all the many cars I have owned. And in the winter, the heat is instantaneous and warm.
REPLY
