- TimCO
- Dec 30, 2019
- Colorado, USA
- 2021 Mustang Mach-E FE, 2023 Bronco Sport OB
- Retired
The cost of the Ford Connected Wall Charger is more than just using the Ford Mobile Charger that comes with the car, for sure. At $799, it's also usually more than most 3rd party chargers.But the cost of the Ford Connected Wall Charger to buy and then have an electrician come and do all the work would cost more than just have the electrician come and install the 14-50 outlet. He still has to do the wiring and the breaker.
But whether an electrician will charge more (or less) for a hardwire connection vs an outlet just depends on the electrician you choose. In theory it's the same basic amount of work and shouldn't cost any different, but some may anyway. As Shutterbug said above, 2 quoted him more, 2 less, and one the same. And only by a modest amount.
Note, however, that it often costs more to run a higher power circuit than a lower one, because it takes heavier wire. So if you're comparing an install of a 60A circuit (for the Ford Connected) to a 40A or 50A circuit, it's probably gonna cost a bit more. Although not much extra (maybe $50). (Unless of course you don't have that much capacity available in your panel, and they have to add a subpanel. That can get costly.)
