- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
I've developed a fix for the wind noise coming from the side mirrors. Previous testing reveled a reduction in noise when these areas are covered:
Others have reported some success caulking the gaps with Dynaflex, but personally I find that a bit sloppy. If the caulk doesn't go well or cracks later on, it's a pain to remove and redo.
So instead I decided to try 3mm window screen retainer spline:
The end result looks okay and does reduce the wind noise somewhat to 62-65 dB @ 70 MPH:
We'll see if it comes loose in time, but I wind tested it to 90 MPH and it stayed put. There is still a small horizontal gap at the front of the door trim (small tape triangle in first photo), I'll need to do some additional testing to see if that's worthwhile to cover or not. The gap is not constant there, so the spline won't stay put. I may try a small piece of PPF to cover that gap.
