markboris
Sonora, CA
Wow. That is so cool. And if you ever do find the time to write this up in the DIY forum, I'll be quite interested! Could be the first mod that really makes me get (and learn) a Forscan setup. Thanks!
Aaron, from scanning over this thread, looks like a lot of members want a dedicated camera button. I’ll for sure write up a thread in the DIY forum this weekend.
Mirak
Kansas
In addition, I really wish they would add much better automatic camera screen options that could be chosen in Settings. Like to have the camera screen activate automatically when getting within 10 feet of any object while in Drive.
The cameras are great but they're really only useful now when in Reverse. They would be great for use going forward too (in parking spots, my garage, etc), but it's too much of a PITA to have to manually turn on. The cameras are great feature just gets mostly wasted. ?
YES!
Mirak
Kansas
Or push the knob to change the mode with some sort of indication either in the instrument cluster or the upper driver-side corner of the center screen with it defaulting back to volume after some sort of timeout period.
The Prius V I had previous to the Mach E had a single dial for the climate control that you'd toggle left/right to change what the dial was controlling (air distribution, temperature, and fan speed from left to right); the only thing that would've improved it was if it defaulted back to temperature, otherwise you'd have to look down to see what the dial was set to.
1. Tap the function. 2. Twist the knob. Seems so easy. The alternatives being suggested seem… more complicated?
Ford Mustang Mach-E Sync 4A Update Overview from Ford - Larger Apple CarPlay Android Auto interface, added dial functionality & more 1669318367880
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Anyone outside the US don’t get excited, according to Ford UK there’s no current plans for this in Europe.
Are we just orphaned users here? We're still stuck in the 2.7.x series. Could it be worth paying for the dealer to carry out all the updates listed in FDRS for our VIN? On the other hand will they upgrade straight to Android Automotive for users outside the U.S. I wonder?
awp0
Aaron
boston, ma
MME Premium AWD ER
Thank you so much! Really appreciate your time on this. Repurposing that button for quick access to the camera is such a great solution.
dbsb3233
TimCO
Colorado, USA
I guess using the knob is OK too but it's still 2 steps (activate the function, then turn the knob). I still prefer just clicking the same spot on the bottom of main screen, even if I have to touch it 3-4 times to cycle through a rotation or to go up or down a few degrees.
Every time I have to "find" a different spot on the screen while driving, I'm taking my eyes off the road to find it. And that's a bad thing. Although I will say that the knob is a better 2nd step than finding a different menu or different spot on the screen, since we can just blindly feel for the knob.
awp0
Aaron
boston, ma
MME Premium AWD ER
It seems like you'll have the option to do it either way (at least for temperature adjust). The screenshot suggests you could choose the knob or the soft +/- buttons.
For seat heaters, I completely agree that there should be a way to cycle through the settings with a single soft button (similar to how heated seats are controlled in every other car). Hopefully we can all agree that the current "slider" for seat heaters is pretty bad.
lolstebbo
SF Bay Area
2012 Toyota Prius v
I'm just thinking in terms of not even having to find the function to tap on to begin with; the knob is such a large target that it's easy to press on versus hunting and pecking.
Mirak
Kansas
To me, repeatedly stabbing away at specific little spot of the screen to use the plus and minus is even harder and requires more concentration than using the slider. You guys must be way more dexterous than me. For me, tap once and twist is the way to go.
I’m oddly enthusiastic about this enhancement because I find the sliders and plus/minus pretty cumbersome.
dbsb3233
TimCO
Colorado, USA
That's why I say the bottom of the screen (or the top, or side). I anchor my thumb or fingers on the edge and can pretty easily touch a button with some precision that way, as long as the button is near an edge. Like say, the AUTO button... fingers on the bottom edge and tap with my thumb.
That's actually one advantage to the "floating" screen that looks like it's just glued on to the dash... gives a nice edge all the way around to anchor onto.
It's stuff near the center of the screen with my un-anchored hand bouncing all over that's the problem.
cmtaylor963
Charles
Springfield, MO
Mach E 1st Ed
This is not guaranteed either. Just because the person I talked to belives that to be the case, doesn't mean it's correct or that things won't change for the better (job 1 frunk wise) once other priorities are dealt with.
Here's to hoping! It just seems like they are prioritizing revenue streams (Alexa, streaming) and JobX vehicles over adding features that have been promised.
OrchidMania
Miami Beach
Grabber Blue Premium ER
Am the only person who lost all connection to CarPlay ? Finally when I got to my destination I turned car off and deleted and reinstalled my phone.
QuesoGrande
2022 Mustang Mach-e ER AWD
I really hope they remove the slider for the heated seats, and make it only a tap feature. Why do I have to tap the heated seats, then slide between 1-3? It should just be a tap like any other Ford heated seats button.. the auto feature can be a button under climate settings since it shouldn't be toggled frequently.
I'm surprised sentry mode wasn't added as well.
bp99
Oregon
22 MME eAWD, 21 MME CA Route 1 (sold)
Completely agree. The sliders are horrible. Especially when the road is not smooth. A simple 3>2>1>Auto>Off > Repeat sequence would be a vast improvement. Pretty much just how physical controls work in many cars. A long press could be used for a one touch Off.
I think there are far too many complications here. First and foremost, storage space. Secondly, there's the question of which supplier each camera belongs to and if streams can even be processed outside the scope of that vendor's features. Of whether or not useful camera angles even exist (it's unlikely that a face would be visible with the side cameras). A sensor to trigger events and wake the camera system. Then, there's the need to stream feeds to a phone. The first issue being processing power (Ford went with the cheapest, lowest performance cpu needed for Sync) to transcode the video to a mobile data friendly streaming format. Secondly the bandwidth cost. The bandwidth cost could at least be covered with a subscription service.
