TSB 21-2307 Water Leak Into Liftgate
DRuth086
Daniel
East Providence, RI
Black 2021 Mach-E AWD Extended Range
Graphic Designer
I take my Mach-E to the car wash frequently (I know, I know) and I noticed a significant amount of water coming into the back hatch as I would towel dry it. Thanks to the forum for pointing out TSB 21-2307! I took it to be fixed, the dealer (which is less than stellar) followed the directions seemingly and said it was fixed. So a few days later I took it back to the car wash and the attached video is what the hatch looks like when I return home. Did they not do something properly or is it beyond what 21-2307 covers? Does anyone else have this problem?
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
That part of the hatch in your video is outside of the seal. That part is open to the outside so it is going to get wet. You can see the kind of line where the seal is actually made. Where the video starts, it is dripping down into the interior part, but its because the hatch is opened and gravity is causing it do drip down.
DRuth086
DRuth086
Daniel
East Providence, RI
Graphic Designer
We used to take our CX-5 (prior vehicle to the Mach-E) to the car wash all the time and never saw any residue or soap inside that very exterior perimeter of the vehicle. Which is what caused some concern. I'm surprised the vehicle would allow so much exterior liquid into the hatch where minor electrical would be.
benk016
Tulsa, Oklahoma
I mean, this is the area where the button to open the hatch, and the lights for the tag are. They need to be exposed to be accessible.
Zobo
Scott
Iowa
21 Mach-e AWD select standard
Well bad news. Mine built 10/1/21 picked up yesterday is doing it. Came here to see if anyone else had the issue. Ton of water came out of the tailgate handle after driving in the rain today.
silverelan
Seattle
As someone who lives in the rainy Pacific Northwest, I don't see how this is a good thing at all. Anybody else seeing this too?
Scooby24
Olathe, KS
Perioperative Revenue Manager
This...the water is outside of the interior seals.
B Gray
Walnut Creek
2014 Fusion. Pre Mach-E Carb Gray
Late to this thread, I took mine in due to a leak and they are saying it is the seals around the tail lights. Also found out there is a recall on the moon roof seals.
FUNgineer
San Francisco Bay Area
2021 Mach-E GT, 2018 F150 Lariat FX4, 2021 X5 45e
Nerd, Dungeon Master
I also noticed this issue today as it has been raining here for a few days. When I opened the rear hatch water was dripping from interior handle in the hatch door. Did you take yours in to the dealer? Did they fix it? What was the verdict?
DevSecOps
Todd
CISO
If your car was built before July 1 then you are eligible for that TSB. Take it to the dealer and get it fixed. If the water is not on the interior side of the seal then it's not a defect, it's just the way it is.
DRuth086
DRuth086
Daniel
East Providence, RI
Graphic Designer
I did take it thinking that the TSB mentioned below would fix it. They acknowledged that my car did need the TSB and did the work but evidently it was not to fix this particular issue. As many have stated maybe this is normal because the water is on the outside of the seal. Just weird. Have never had a car that holds this amount of residual soap.
jlEMach
Josh
Los Angeles
Fusion Hybrid, 1982 Range Rover, MB E450 Wagon
Accounting
Yes, ours picked up 11/30 has the problem
Mirak
Kansas
Same issue. Doesn't bother me, but I did have to make some modifications to the car washing process because water builds up in the gaps around the liftgate and then slowly drips out leaving streaks and spots. So now, after washing the car, the first thing I do is open the liftgate before I start drying, which allows that water to drip out while I'm toweling it down.
