10k service $130!?!
ThatGuyLando
Iowa
22 CR1
Software Developer
Go somewhere else I just had mine done, like $24.ended up using fordpass points making it free.
0CO2
0CO2
Philomath, Oregon USA
MME FE
Academic
Kendall Ford in Eugene Oregon did 1-yr and 2-yr annual servicing as well as numerous firmware updates, replacement of faulty modules (to get my electronic frunk release to work) for my 2021 MME FE for free. I didn't even buy it from them. Kind of shocked to hear what other dealers are charging...
Fixbear
Frank
ADK. foothills, NY
That's odd. Took my 21 in for 10K and it was free.
Sneezy
Sneezy
Central NY
2000 Trans Am Firehawk, 21 Mach E Premium EXT.
NRA Rifle Instructor
My dealer even suggested I use the points so it would be free.
Valkyrie
Robert
Honolulu
2022 Ford Mustang Mach-E GT Performance
Future Prediction
Mine cost $30 in Hawaii.
Whether a dealership charges for servicing, or what they charge for servicing, is a dealership decision. That's why it varies.
If a dealership is replacing / updating modules under warranty, they can't charge you.
There is no such thing as preserving the warranty by having the dealership do service for you. This point gets made again and again, but it's simply wrong.
rmins
rmins
Ryan
Ann Arbor, MI
2022 Prem Mach E SR RWD
I went to Gene Butman Ford in Ypsi for my interval servicing twice, and they were quick, priced at $27 (I just redeemed my points), picked up and dropped off my vehicle from my home, and performed all the required S/W updates when they had my MME. I'd surely recommend them (I hope it's not them that quoted you this insane price).
Thanks for that info. It was not them, it's Briarwood Ford in Saline. I'll check out the place in ypsi.
DevSecNetOps, General PITA
They has to fiddle with the things to replace a $10 air filter and switch to summer air in the tires.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
I brought my car in for a tire rotation at 10K. Just checked my invoice. It was $19.95 for the tire rotation and they updated BC maps and an HVAC module at no charge. So $130 does seem quite high.
The Ernhart Ford ALWAYS screwed up my 'service' on my FFE. I'd bring it in for the tire rotation. Why you ask? Because Discount seemed to destroy these stupid capped lugs at were 17.37546774mm. So every 3rd free Discount rotation cost me a set of lugs if I ever wanted to take the tires off. SO I take it to E. Ford. They charge me $39.98 for an oil change and rotation. What oil in said EV got changed folks? "Oh yeah sorry about that we only have 1 code. I'll credit you back" Which usually cost 2 or 3 more phone calls days later when it wasn't credited. Sadly they have to be rotated as it's FWD.
ca_jon
Jon
2022 Mustang Mach-E Performance
Dealership wants to charge $130 for the 10k maintenance for my mach e. Is this for real? I've seen other posts show $20 or $30. I'm in SE MI (Ann Arbor area). This is the dealer I bought the vehicle from, should I avoid them for this service?
Seems reasonable to me, except for the 6 month/5K miles part.
TheSleepyDad
SoCal
2021 GB GTPE
I'm in So Cal and my dealer quoted me like $115 for both 10k and 20k service, both online scheduler pricing and on the printout when I dropped off the car. Dropping off the car for the 10k though they told me something like "but it will probably be cheaper."
Sure enough, both 10k and 20k service were $20-$25 out the door.
spgordon57
Moraga, CA
2022 Ford Mustang Mach-e
Dealerships make most of their income from servicing cars, not selling them. They are rightfully nervous about the EV revolution, as it will radically alter the dealership business model. Charging for needless 10k and 20k services is a way to mitigate or delay that inevitable outcome.
epec
Wensen
Houston, TX
2019 Ford F150, 2022 Ford MME
mine 10k service was 28$ , which cover all inspection and tire rotation. the service advisor told me if i have jack and tool, i can do that at home
