It won't be a FordPass update that brings that to Job 1 cars.
Actually, a long time ago, some job 1 owners reported seeing a (non-working) frunk button in FordPass that quickly went away.
MachEnthusiast
Seattle, WA
2021 Mustang Mach E GT
Software PM
This version of the FordAss app is crashing on an iPhone 13 pro max, all updated. Anybody else having the same problem. Rebooting, removing and reinstalling has not solved the stability issue.
Weird. I have that exact model of phone and it's working fine for me.
roamtheworld
Austin, TX
2025 Mach E Rally in Molten Magenta
I think that is normal with this app. For some it works fine others it doesn't work.
Same phones with same OS's on either Android or Apple and it never is consistent in operation.
2021-MMEx-RT1
CA
2021 MMEx CA Route 1
Yes
I think I’ll stick with 4.17.1 for now. Not seeing a clear need to update given all the issues being brought up.
So far my iPhone 13 Pro iOS 15.6 works just fine with FP4.19.0
RMoore
Rob
Good to know since I have the same phone and iOS. Did it fix anything that wasn’t working previously with FP?
I never use the map charger function in the Ford app but mine is in Germany as well. Not much help here in Texas but next time I road trip to Germany I'll be all set. :p
I just looked at my charger map. It shows the area around my car. ?‍♂?
TruWrecks
Oregon
Mach-E Star White Premium AWD Ext (Ghost Stallion)
Still on 4.18.0 on Android. Ford will probably push iPhone to 4.25.0 before they send a new update to Android at this rate.
2021-MMEx-RT1
CA
Yes
Not exactly sure. The two main issues I've been having is the charge indication, and I won't charge until tomorrow so can't say.
And yesterday I received OTA 2.8.3, and I can't get the notice to go away.
It's on the main screen, I tap it, it tells me Update Successful. but when I return to home, it's still there
I'll go to vehicle and the badge says Vehicle Status 1 'Alert' (why call it an alert?). Tap that and it opens Active Alerts, tap that and it again tells me Update Successful
Go to Accounts, Message Center and there's no notice there about 2.8.3, however, there are two notices about Blue Cruise, but they are marked as red.
Meh. Off/On the app, Off/On the phone. Still have ALERT!! Danger Will Robinson!! You have a Successful Update!
I can ignore it.
dcbr
don
S.W. Michigan 49008
Subaru outback, 2021 Mach-E (sold) 2024 Mach- E Premium ER RWD
Preferred charging location problem. Don't know if it is a result of the FordPass update or the recall update. I got both the same night. I lost all my previous and saved charging locations and not able to add a new one.. The app is asking me to begin the setup for preferred charge times but I cannot do that without having a previous destination or saved destination. Any suggestions?
The recall update wiped my charge locations. I always setup charging in the car, never the app. Seems more stable.
