GT Performance Edition winter tires
Iknownothing
Colorado
Explorer ST
In the past, I've been given advice that narrower tires give better traction due to a smaller surface contact area, but I've gone stock size the past 10 years. Dedicated snow tires now are pretty good and here in Colorado most of the winter is actually on dry pavement. So, the stock width should work well.
You are right about supply issues. I ended up going with the Vredesteins. I've had Blizzaks (great), Michelin Artic Alpins (fun, but ok in snow) and Pirellis (terrifying in snow). The should be available towards the end of the month. The supply chain issues seem to be getting worse, so I jumped rather than trying to make a winter on the GT PE summer tires. Been there and done that a long time ago. Not doing it again.
What made you choose the Vredesteins over the blizzaks? Also, where did you get your tires? I might mimic you and we will have twin cars (mine is a few weeks behind yours). This will my first Colorado winter in a long while and never with winter tires so I’ve very much appreciated reading your opinions here.
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
I buy tires now at Costco or through TireRack. These I got through TireRack and they are being mounted on a set of wheels with pressure sensors.
I got these wheels
ASA GT14 Gloss Gunmetal Silver Painted (tirerack.com)
Because I have a GT PE, I just won't try to make it with summer tires. If you are just getting winter tires and need them mounted, I would recommend selecting SJ TIRE COMPANY as the installer. They come to your house with all the equipment on a trailer.
I went with the Vredesteins as they had really solid ratings and they seem worth a try. We put Blizzaks on my wife's Audi Q5 though.
Colorado can have some very interesting days in Winter. I don't know what your employer has as a policy, but post-Covid I suspect that there will be more flexibility in remote work.
You can ping me if you want me to look at tires or such.
Eric
phidauex
Colorado
Renewable Energy Engineer
Just adding another voice for both the Vredsteins, and SJ Tire. I chose the Vredsteins mostly due to their good reviews, reasonable price in the size I wanted (235/60-R18), and sometimes I just like to try something new. The last 15 years I’ve either had Blizzaks or Hankook Icebears, so interested to try out the Vredsteins. They certainly look beefy.
SJ Tire did my install as well, came to my office to get it done. Very quick, programmed the TPMS sensors, hand torqued, no scuffs or silliness. I had new wheels in boxes (Jaguar takeoffs) and they broke down the boxes to protect my interior before reloading my stock wheels and tires into the back, which was a nice touch. Small company, seems like one guy plus helpers, but my experience was great.
As for CO weather, it can certainly be unpredictable, and I don’t like being told I can’t go anywhere, even if I choose not to. ;) I’m a big proponent of having winter tires on a 2nd set of wheels.
One thing a lot of people forget is that tires only age with mileage, so if you drive less this winter than usual - no problem, that just means the tires will last you longer. The only added expense of winter tires is the wheel set and the initial labor, everything else evens out because you use each set of tires half as much, so they last twice as long.
mschian
2021 Mustang Mach E PE and Ford 2019 Ranger
New Car Sales Northgate Ford Inc
Boy, not a lot of tires available in 235/45 that have an stock or better load rating (103 XL). Many are available as 100 XL, which is good enough on paper, but most people prefer to stick with the stock load rating or higher.
In 235/50 you get the Pirelli Scorpion Winter which looks pretty nice, and claims EcoFocus, though I don’t know what that really means. https://www.tirerack.com/tires/tire...0SCORWXL&vehicleSearch=false&fromCompare1=yes
I'll check them out. EcoFocus usually means better fuel economy. They get fuel economy by a lower rolling resistance. Has something to do with sidewalls. There is a formula for calculating it, I just don't know I'm smart enough to figure it out, it didn't sound simple.
AButtonMasher
Detroit, MI
Ford Mustang Mach E GT Performance Edition
Designer
So I got Michelin All Season 4s and I’m a little nervous in the range hit I’ve seen so far. In the Pirelli’s I was getting 2.8-3.5ish, now I feel like I’m seeing more 2.25 to 2.8 ish. This being said, the day that I put them on Michigan has been about 20 degrees cooler. So I’m likely seeing that as much as a factor in the tire too.
harrysiii
Harry
New Hampshire
2025 Ford Bronco Badlands Sas, 2025 Toyota Grand Highlander Hybrid MAX Platinum
I just ordered a set of Bridgestone Blizzak LM001 winter tires to go onto my stock GTPE wheels. I'll get another set of wheels to mount the summer tires on. Winter setup goes to be installed 11/2/21. :)
Steve-o
2021 Grabber Blue MME-GTPE
Staying with the 20 x 8 rims is impossible to find right now as supply chains are causing issues. I don't want to put $4K rims on the car to just get hit with snow / sleet / ice and destroyed. I might need to take this approach ... oh wait Im still in the grumpy I have no idea when I will get my car so who cares haha
Brandini00
Brandon
Youngstown, OH
2022 Cyber Orange Mach-E GTPE
Hello, I currently have some 255/45R-20 MICHELIN CROSSCLIMATE2 XL that I would be swapping out the oem summer tires for. Does anyone run a tire in this size or does any have a comment on the extra width/aspect?
Thank you, Brandon
Thank you, Brandon
HI Brandon, welcome to the forum and those Michelin tires are only one size up from your OEM tires and there will be no issues running them on your car. I have been running 255/45/20's on the front for over 7000 miles and no issues and there is even more clearance in the rear.
Brandini00
Brandon
Youngstown, OH
Thank you! Correct me if I am wrong but I believe the GTPE sits lower than the car you have now. But like you ssaid, should still be plenty of room. Looks like it is only 1.4% higher than OEM in the tire calculator.
Yes the GT and GTPE sit about .5" lower than the other Mach-E models. Still no concern for your 255/45/20 tire in fitting.
locks66
Minneapolis
2021 Mach E GT
Got to give my winter tires/wheels a real test today….
Continental Viking Contact 7 245/45r20 on Velox wheels.
How did this fair for you? Any updates from anyone else in this thread? Standard GT and live in Minneapolis and just got our first snow. I'm a Realtor who drives 3,000 miles a month and never have done snow tires ever.
