[Guide] Better Jump Point Access (Battery Access)
Mine too with the positive terminal but access is still fine.
I went with the 2-1/2" caps and moved it to be closer to over the jump posts.
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) IMG_9018
That was my project today.
Mosworthy
Shane
Thunder Bay, ON, Can
2021 Ford Mustang Mach-E Premium AWD SR
Manager of Paper Operations
Heh...
Canadian Problems
Same hole covers are $14 on Amazon.ca
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) 1641845526139
bcb
South Central PA, USA
2021 MachE GT PE Prius Plug-In
Retired (former software engineer/cloud analytics)
.... FWIW, I did not remove any of the plastic shrouding. I just lined up the holes by sight based on other people's pictures and used a two-inch hole saw. Easy-peasy.
Nice! Lazy me might just do it that way. not looking forward to removing the trim panels...
ReelSweet
Jody
Connecticut
Mustang Mach E
DevSecOps
DevSecOps
Todd
CISO
You used a 2" hole saw drill bit and the 2.5" caps fit? I have a 2 1/8 bit and wondering if the caps work. I would have thought the bit needed to be 2 1/2.
I'm pretty sure that's a typo. The cap size would be the same size as the hole that was drilled.
SteveJo
Chadds Ford, PA, USA
2010 Ford Fusion Hybrid, Job 1 Mach-e/X
I have fixed my error. I meant to add the diameter of the cap top. Tks for the catch.
SteveJo
FWIW: These 2.5" caps fit very snugly. I have removed the caps a number of times with only my fingers in warm weather. Recently, in frigid weather, I had to use a pry tool .
KevinS
I took needle-nose plyers and pushed the tabs in. I also did a gentle sanding of the plastic thickness to remove burrs. They seem to be OK for me and hopefully won't rattle in the summer. ?
Can you post a picture with the caps removed? Is the crossbar exposed at all?
I moved the hole location a bit from the template to improve access to the jump points and avoid the crossbar.
Ford Mustang Mach-E [Guide] Better Jump Point Access (Battery Access) EEE69045-F045-4D8C-98FB-8A86D65F8308
Neil4Real
Well, if anyone else butchers it like myself lol the part number is: LJ8Z5802038C Cowl Side Panel
I'm able to use my Ford Pass points, don't have much else to use them on, so why not! I just whiffed it with my hole saw... lol. Oh well, live and learn!
