BCMatt
Matt
BC
2023 Mach E Premium Extended AWD, 2020 Tesla Model 3
Using a combination of information I got from this site, Reddit and the Mach E wiring diagram I got from easymanuals.co.uk , I added the physical tailgate release button to the headlight switch cluster. This replaced the max defrost button, which I considered to be useless.
At the same time I also added the power liftgate close button to the hatch itself. This button was installed on early Mach Es, but removed by Ford for cost cutting. I also added a front and rear dashcam at this time, but the focus of this thread are the tailgate buttons.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007766
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007767
A lot of my information I grabbed from this thread: https://www.macheforum.com/site/threads/adding-an-inside-liftgate-power-switch.6560/
First, I disassembled the donor Bronco/Explorer headlight switch to get the hatch release button. The Bronco headlight switch is similar to the Mach E's, but is missing the traction control button, and has a fog light button so it can't be used directly.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007785
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007786
Taking the switch apart is extremely easy. Pry off the faceplate at the tabs shown, then remove the hatch release button with the next set of tabs.
Remove the Mach E headlight switch assembly and do the same thing to it, removing the max defrost button and reassembling with the Bronco's hatch switch. The switch comes out easily if pushed out from behind with your hand. Gain access by removing the side panel from the dash with a plastic trim removal tool. This just pops out with gentle prying.
Connect a stranded 20ga wire to one of the WT1002 pins, and add the pin to spot 12 on the headlight switch connector. I used solder and shrink tube to connect my wire, you could also use crimp connectors. Run this wire down from the dash to the trim pieces that run along the door sills all the way to the back of the car. The wire is easily tucked under the trim pieces without having to remove them. I saw one user who ran this wire along the headliner, and unwittingly ran it over the curtain airbags. Don't be this person. Also, that route is harder anyway.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007787
Once your wire has been run to the back of the car, continue to run it up the plastic trim until you have it in the rear headliner. The headliner can be gently pried down to allow access. Run the wire to the flexible boot that leads to the hatch. Your goal is to run the wire through that boot. This isn't hard, but it isn't easy. First, all the trim has to come off the tailgate. Starting near the hinges and working toward the latch, gently pry all the trim off. The only tools you need are your fingers and plastic trim removal tools. The last panel has a light in it, so be careful to disconnect the connector when removing this. Next, pull the left flexible boot out of the holes on the car side and the hatch side. Run a copper wire through the boot as a fish, and pull your release wire through with that.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007772
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007770
Now that your wire is at the tailgate, zip tie it into place and connect it to another WT1002 pin. This will get inserted into spot 19 on the grey connector of the RGTM module.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007788
Your front trunk release button should now work. Next I added the rear closer button. This is an illuminated button and power for the light would normally come from the BCM. For ease of installation, I tapped into the tailgate interior light instead (not the license plate lights like a different user, I think the logic for the interior lights is closer to what I wanted). I used wire taps for this, although soldering and heat shrinking would've been neater and in hindsight I should've done this.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007769
The stock Ford connector for the closer switch is absurdly expensive, so I used generic Amazon pins and a healthy amount of hot glue to connect to the switch and hold and insulate everything in place. You can also use WT1002 pins in place of the Amazon ones.
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007782
Pin 6 of the switch goes to pin 20 of the grey connector on the RGTM (right next to the one I added on pin 19 in the previous step). Pin 2 is grounded at the interior light connector as shown above and pin 3 picks up power for the light here as well.
Hope you enjoy these mods as much as I do. Good luck!
Part numbers:
Headlight switch assembly: SW-8816
Rear close switch: JL1Z-54432A38-AA
Rear close switch cover: LJ8Z-5840726-B
Connector pins: WT1002 (two required for front button mod, four required for rear button mod)
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007768
Ford Mustang Mach-E Installed Physical Tailgate Release Button + Power Liftgate Close Button 1000007774
This was my third favorite mod. First was the sway bars. Second was the tow bar.
I used that rear hatch button almost every day. The max defrost is a useless button.
areacode413
MA
MachE
I assume the rear hatch module will not open if you accidentally press the button while you are moving?
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Correct. It only opens when the doors are unlocked (and the car is in Park, I think).
I use the max defrost button often on winter trips on legs where we are trying to minimize heater use. Unfortunately, turning it back off still requires one to turn off the rear defrost in addition.
I feel the physical button is not needed because there is a max defrost button on the screen. It would make sense to have an additional physical button if the screen button were hidden under multiple menus. But it's right there, on top and always available.
The hatch button is hidden under a menu somewhere, and unavailable if the car is off. I often would turn off the car, open the door, and as I am exiting hit the physical hatch button, so the hatch is open by the time I get around to the rear. It is so much more useful than a max defrost button, IMO.
creedda
Orlando, Florida
2023 Mach-E Premium RWD
Yup this is a great mod. Did it myself and really love it. Hope Ford sees this and adds it for future models.
BCMatt
Matt
BC
The doors can be locked, but the car must be in park. The button will both open and close the tailgate.
hartmms
Phoenix, AZ
Mach-e GT-PE, Ram 2500
engineer
Too bad no one has reverse engineered the can-bus codes for the tailgate. Adding a little microcontroller behind that hatch button to send the open/close code would be a lot less invasive.
And yes, I'm too lazy to reverse engineer them myself.
BCMatt
Matt
BC
Although the RGTM is on the canbus, it does not appear to get opened with a canbus message. Even the BCM triggers it with a physical wire. Some people have intercepted the wire from the BCM instead of running a wire to the tailgate, but the functionality is not correct (doors must be unlocked, car must be on) with this method. Wiring the button to pin 19 enables the correct latent functionality that exists in the module. If you trace the wiring diagram of other Ford vehicles with the factory release button, it is wired to pin 19 of the RGTM.
Anyway, I am confident that running a single wire to the tailgate is a lot less hassle than putting an arduino on the canbus, coding it, wiring it to the button, etc. Running the wire was very little work; the hardest part was getting it through the boot.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Interesting; on my 2022 the doors need to be unlocked.
Neopifex
Concord, CA, USA
2023 Mach-E Premium (Cyber Orange)
Web Nerd
This may be a dumb question, but is replacing the Max Defrost button with the Bronco/Explorer headlight switch panel optional? That is, does the button/switch itself matter since you're redirecting its wiring, or do you need the tailgate button in order to send a specific open/close signal?
Just asking in case someone wants to save a few bucks by applying a sticker to the existing button. :)
BCMatt
Matt
BC
It could be done, I think. The max defrost button triggers a different pin in the connector. Optionally, you could intercept this wire, snip it and wire the connector end to the RGTM. I would have to check the wiring diagram to see which pin the max defrost is connected to. If I find it, I'll post back.
Personally I think the button replacement is considerably more elegant (it's illuminated and has the correct symbol) and the switch isn't that expensive, but it's personal preference.
Edit: The Max Defrost button triggers pin 10.
I'm that person who first posted this mod in '21. Intercepting the wire from the BCM is very easy to do and takes less than 15 minutes to install your own switch (I've done this to at least 10 Mach-E's if not more) or just a bit longer to replace the MAX defrost switch as many of us had done back in '21. While the doors must be unlocked, the car does NOT have to be on.
