Oh, good catch. I would never have made that connection.WOT = Wide Open Throttle AKA flooring it
Not World of Tanks...
WoT is a tank mmo game. Hence the joke. Come on guys, it wasn’t that hard. It only took me till I got to the next page to figure it out. And I’m slow.
Yes, it went over my head, and my reflexes were not fast enough to catch it.It was a joke. If you ask Google what WOT stands for, you find out many would think it's World Of Tanks.
That is how inscrutable this topic would be to a new person reading it.
I used search box on forum to figure it out. WAY too much jargon/acronyms on web.It was a joke. If you ask Google what WOT stands for, you find out many would think it's World Of Tanks.
Wow, that is so much better than my battery is doing. I plan to do another 100% charge today and see if the SoH improves again. I doubt it will. Probably there is some averaging going on, and one charge above 92% of 91 kWh isn't sufficient to get the SoH to change. But multiple might. Who knows?I just stumbled across this thread and checked mine through CarScanner. Mine is showing 94% with 63,300 miles. I have one of the earlier cars that came off the line.
Warranty kicks in if it falls below 70%.The real question is how much degradation is enough to trigger warranty replacement?
My HVB SOH was at 97.5% before the HVJB replacement. After the replacement it was back to 100%. Think those readings can be messed with and do not hold the same legal weight as the odometer. I mentally add 2.5% to the reading now as it was the HVJB and BECM that were changed not the battery.I just rolled over 20,000 miles and this is actually the first time I have looked at the state of health for the battery (97.5%). This is what it looks like after 3 HVBJB replacements and a lot of back road country driving. Maybe just like humans, exercise is really good for battery SOH.
I have the L2 home charger set to 85% and charge when it gets under 50%
I have around 10 DCFC over the entire year of ownership
I charge to 100% on weekends since I do a lot of back road driving Saturday and Sunday
Car is driven daily
You can confirm the SoH by conducting a full 100% charge. Then divide the Energy to Empty (EtE) by 91 kWh and that is basically your SoH if the battery is warm (70-80 degrees F). I did a 100% charge on Tuesday and the EtE was 84.9 kWh, which is 93%. The car is currently reporting a SoH of 92%, but I think if the car will consistently charge to 84.9 or higher, the SoH reading will increase. That's my theory!My HVB SOH was at 97.5% before the HVJB replacement. After the replacement it was back to 100%. Think those readings can be messed with and do not hold the same legal weight as the odometer. I mentally add 2.5% to the reading now as it was the HVJB and BECM that were changed not the battery.
These are just my thoughts based on reading I’ve done and what (little) I know about batteries: both the SoH and EtE have inaccuracies introduced by battery cell (pouch) imbalances. In theory, deep discharge/charge cycles can reduce cell imbalances and result in more accurate readings. But I don’t think optimizing the measured numbers changes the actual SoH appreciably.You can confirm the SoH by conducting a full 100% charge. Then divide the Energy to Empty (EtE) by 91 kWh and that is basically your SoH if the battery is warm (70-80 degrees F). I did a 100% charge on Tuesday and the EtE was 84.9 kWh, which is 93%. The car is currently reporting a SoH of 92%, but I think if the car will consistently charge to 84.9 or higher, the SoH reading will increase. That's my theory!
