sotek2345
Tom
Upstate NY
Engineering Manager
My kids are constantly going to sports and martial arts.... hands full of gear and when they come up to the car with their hands full, I open/close the hatch constantly. And with the loss of the kick-to-open feature gone for 2022, it's even more helpful.
Ah ok - whenever I take my kids to things (usually robotics, not sports), I am going with them, so I am getting out and unload/loading the back.
jmatero
jmatero
San Jose, CA
2022 MME GT-P
I'm still confused as to why there is a hard button for the Max Defrost when there's a soft button always present on the screen.
Ford Mustang Mach-E Traded Tesla Model Y for Mach-E GTP - a Comparison IMG_0642
db4z
TX
Focus RS
Safety reasons - if your screen fails you can still safely drive the vehicle by being able see in poor weather by being able to turn on the defroster.
Mirak
Kansas
Ok - I am really curious what your use case is that makes you want to open the hatch from inside so often. 99.9% of the time I want to open the hatch, I am behind the car wanting to put something in or take something out. I have opened the hatch from inside exactly once when I picked up some pizza.
Do you have kids? I probably spend 15-30 minutes a day on average in somebody’s driveway, or a parking lot, dropping off or picking up. And it is always “hey Mr. ___ can you pop the trunk?” This is not uncommon at all with kids. And it’s why I’ve never ever been in a car where you couldn’t open the trunk with one push of a button.
Mirak
Kansas
Let me rephrase: I’m still confused why there is a button on the screen for max defrost when they already gave us a physical button. We can’t have one-touch access to the trunk or the cams, but we’ve got built in redundancy for that defrost! Got the defrost COVERED.
Neil4Real
Sounds like you need to enable the kick to open liftgate on your 2022 using FORScan
I keep my grocery bags in the rear compartment. It’s much easier to open the hatch as I am getting out of the car than to open it after I get behind the car. There are other reasons as well, like when I pick my sister up, it allows the hatch to be opened without my having to open it for her from behind the car. ??
We have a redundant button in case the first button fails?
But what if the 2nd button fails? What then??
If your reason was the reason for redundancy, we would have a physical button for everything.
scoopman
Bay Area
Somebody needs to make one of these for the MME.. basically low power Bluetooth buttons that fire CAN-bus messages.
https://abstractocean.com/products/s3xy-buttons
One could program a button for hatch, frunk, drive mode switching, 1PD on/off.
The Tesla aftermarket eco-system is simply larger right now due to the the cars being on the market for longer and more on the road. MME will get there.
Yeah -- this would be great. Anyone know if this would be possible on the MME? Could be a large(r) market if there are similar control protocols used across multiple Ford models. Someone needs to do some OBD port hackery please.....
SWO
MD, USA
It's a PITA when the wife is either dropping me off or picking me up from the airport, for one.
ARK
Los Angeles
'21 Premium SR AWD
I don't know specifically about those bluetooth buttons, but a forum member had created a DIY liftgate switch - see here.
scoopman
Bay Area
Yup but these buttons are great because there’s no wiring required and you can dynamically program their function
Reactions: ARK
agoldman
Charleston, SC
very good write up! Thanks.
voxel
Nelson
Altamonte Springs, FL
22 Mach-E 4X, 23 GC Limited
I've pinged the engineering company that designed it - https://enhauto.com/commander-full
All the hardware should be the same... the only difference would be CAN-bus programming/messages I suspect. Unless it's all encrypted data like new Toyotas.
