ab13
Rav4 Hybrid
Few more things.
When I rented a Ford Fusion, I got used to the rotary shift. I found that if you keep turning it will stop at D, so I didn't need to look when I selected D. R was one click out of P, so that was easy enough. This appears to be the best option to reduce space, provide L button, and use existing Ford part designs.
Redundant
Mach-E 4X-Space White, 1 Ford Flex, 2 Ford Escapes
Doesn’t the screen in front show the gear you are in?
PaulD
England
Audi Q5, Jaguar XK, Peugeot Bipper Tepee
Semi retired management consultant
Few more things.
I really like the rotary dial location on my Jaguar XK. Particularly with the similarly located start button. Admittedly I only ever looked at when reversing or parking not bothered by an L position.
Ford Mustang Mach-E Tru's thoughts on the Mach-E from second driving experience 62FF1519-7AB9-447A-A3D1-B47D46E1424D
This is the descriptive review I have been looking for! Hit all the points that others have missed. Thanks Tru!! Very helpful.
This isn't a review, this is @trutolife27's "Confessions of a Mach-e Driver." ;)
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
Normally you will only get a fix-it-ticket if you get stopped for something else.
I saw ton of teslas not having front license plate here even though CA supposes to enforce it. So Ford should really leave the decision to the customer..
VegStang
Leo
Silicon Valley
Yea, I have seen number of Tesla ones off-center, crooked etc. But mostly not there at all.
Do like the idea that these were just stuck on. The one M3 that I saw that had the license plate sticker on the front wasn't really a lot better than the bracket now that I think about it, especially knowing that the bracket is just stuck on with tape anyway.
Also easy to go on crooked or not centered probably.
The Mach E should have considered holes that are accessed from below the bumper.
Jim Glass
Tybee Island, GA
2021 Mustang Mach E First Edition, 2019 Audi Q5
For me, I think it's too far back. Needs to be further up, Or let the seat go back more. Plenty of room with the seat position But sometimes I like to rest my arm there. Just felt like the armrest needs to be moved up some. Also when you go to look in the middle compartment you kinda feel it's moved back too far. Just my take on it.
The situation with the arm rest is something I’ll never understand. Every Audi uses an adjustable center arm rest. It’s not complicated, just plastic that lets you move it forward/backward maybe a total of 8-10 inches and adjust it up/down another 4-5 inches! Maybe they have it patented? But it’s so simple I don’t know why every manufacturer doesn’t employ it. It’s one thing I really like in my S3.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
The Bolt's armrest slides forward for adjustment....I can't stand it.
I like the armrest all the way back because that is the only position it will let you open it to get at your junk stored in it. The problem is that with someones arm resting on it and coming to a stop causes it to slide forward.
MY21 J1 Premium RWD SR
CR-V has a sliding armrest and I find it annoying for the same reason. It slides when I don't want it to.
Badger_Prof
Randy
My Bolt does that also.
VegStang
Leo
Silicon Valley
Our Mercedes electric has a sliding center arm rest, no problems with it moving once it's set into either full forward or backward position.
ajmartineau
Washington
2021 Mach-E
When we bought our Bolt, we didn't know it slid forward. We called the dealer to tell them the damn thing was defective because it wouldn't open. ?
