- Sep 5, 2021
- Florida
- 69 Mach 1, 11 GT, 21 GTPE- sold, 24 Taycan 4S, 20 F type R
I wouldn’t call it a wild guess, more like an educated one based on the data.We're just guessing whether it's timed, or based on one of the temp sensors.... unless there has been a post from Ford Engineering I missed?
My bet is that it's temp, but I dunno WHICH sensor. Probably not ambient, but likely to be any or all of the internal motor, inverter, battery sensors. Most likely a sensor buried in the battery tray.
I can tell you from my own experience with my eMiata, that pulling 5C or 10C through connections that are designed to handle continuous current of no more than 1C has a pretty quick effect unless the heat transfer is optimized to cool the cells. External air cooling won't help *much*. I'm talking about coolant chilled as cold as you can get it to extract as many BTU as possible.
since we can't easily open up the battery pack to optimize the internal heat transfer plates, the only thing we can even try to modify is the inlet temp of the coolant prior/during heavy loads. If I were a drag racer interested in modifying to see if I could squeeze out another second or two at full current..... I'd test the theory since I doubt we're going to see an official response from Ford Engineering on this.![]()
Is it time or temp? The answer is likely both.
They program all these things using tables (looks like a giant excel spreadsheet). Some are closed loop and some use open loop feedback.
Short answer? At full throttle things happen too quickly to rely on open loop feedback. The 5 seconds is likely a hard stop. ICE vehicles do the same thing at full throttle.
However, feedback like battery temp, external temp, vehicle speed, etc can affect things BEFORE you go full throttle.
That’s why the “grey bars of disappointment” show up in the power meter sometimes before you floor it, or faster than 5 seconds after you floor it.
What has never happened (so far) is anyone getting more than 5 seconds. Doesn’t matter if your battery is perfectly warmed up and it’s cool outside. 5 seconds is the current hard stop.
