Guss-E 2021
- Pierre
- Aug 12, 2021
- New Hampshire
- 2022 Mach-E Prem AWD ER
- Compliance Specialist
I finally tried DCFCing at an EA charging station. I was in no hurry and didn't really need to charge. I just wanted to see if I could use some of the free kW that come with the MME.
I know see what all the YouTube criticism is about. When I pulled up to the four chargers there were two ID.4s and a Mach-E already charging.
Issue #1: Charger Placement
There were four charging station, each with two cables placed parallel to the spaces. The layout, when faced from the aisle, was: space, chargers, space, space, chargers, space (see attached photo at the bottom ā taken from PlugShare app fyi). With the exception of the top left charger in the photo (when facing from the aisle), no matter how a Mach-E pulls in, the charge port is not near the charging cables. Nose in (motorcycle space) and the cable facing the space barely reaches the port. Boot in, and you have to drag the nasty hose across the hood (um, yah no thank you). Even then the cables are so inflexible, I doubt. youād be able to twist them so as to be able to plug in, if they even reached at all.
NOTE: The photo is not of the moment I was there. When I pulled up, the left side chargers were occupied by the ID.4s. (including the one space that could have worked easily for a Mach-E). The Mach-E was parked in the space occupied by the motorcycle in the photo. It was nose in. It was able to simply pull the cable from the charger in the top right around and plug in. Of course, if it was raining, and you wanted to sit in your car, youād have to keep getting out and walking around the charger to monitor your session.
By contrast, the charge port on an ID.4 is on the rear side of the vehicle. This, to me, explains the choice of positioning for these VW owned EA chargers. The ID.4s could simply park in the space with the passenger side closest to the charger and their ports lined up. How nice for them.
Issue #2: Initiating Session
As I circled around to position my car, the other Mach-E left (motorcyle space) so I took that spot. The right cable on the charger facing the space was Charger #2. After setting up my EA app (I went with the no monthly charge option for my test) I was able to initiate charging. However, I was unable to get Ford Pass to activate my free charging on #2. Then I got a charging fault. I gave it several more tries, plugging in first (as instructed on the charger), not plugging in first, restarting my phone, clearing cache, etc. I ended up moving my car to the other side, boot in to try out #1. This time I was finally able to initiate free charging. On a side note both EA and Ford Pass need to do a much better job if indicating free charging is in session. It was not until I was done, that the charges display indicated I had not been charged (double check my credit card to be sure). I consider myself a tech savvy individual and it was simply too much work to intiate a session.
In summary
Iām telling you it is this shit that will completely turn off ICE owners. Yes, Iāve had some POS issues at gas pumps as well but those were due to a malfunction with the pump or the POS system. The nonsense at the EA station detailed above is essentially the result of poor design. Even if everything had worked perfectly from the start, it was still way too many steps, too much vehicle wrangling and too many taps in the apps.
In comparison to the above...
This account is not me bashing public EV charging. It was specifically to share my first Electrify America experience in light of all the bad press EA is getting right now. Iāve only DCFCād two other times in public (so my test sample is likely much smaller than others in this forum). However, I can only speak to my own experiences thus far.
The first time I charge in public was at a Ford dealership in St. Johnsbury, VT. The second time was at the Town Hall in Richmond, RI. Both times I used brand new ChargePoint chargers. They were located at the top of the space and the cable easily reached my charge port. In fact, it would not have mattered which fender the port had been near, the cable would still have reached. Even easier for cars with ports on the front or back.
Initiating charging was easier than starting a fueling session at a gas pump, yah easier. At the gas pump, I would have to insert my credit card, wait for the prompt to insert my loyalty card, wait for authorization, select my grade and then start fueling. Now mind you, when I charged in St. Johnsbury, I had never used a public charger before. I had unlocked my phone and opened the ChargePoint app because I assumed I would need to. The lovely large, bright touchscreen display told me to tap my phone to the screen so I did. It then told me to plug into my car. That was it, charging initiated. I was only charging at 62 kW but it was more than fast enough for the 40~ miles or so I wanted to add back on. The chargerās display was great. Big text and numbers with charging rate, miles added, incurred cost and time on the charger all displayed and easy to read. I had the same experience at the RI charger.
So now I say WTF EA? Based on my two ChargePoint sessions, it appears that it is possible to have a āTeslaā like CCS charging experience. The only improvement I can think of would have been true plug and charge (no tapping of the phone at all). But if the only extra step I have to do is tapping my phone to a screen, I can live with that. I guess EA just got another round of funds from VW to improve things. Hopefully beyond simply putting new stickers on its chargers. Well if you have actually read this far, thanks for indulging me.
In summary
