kirkus02
Kirk
SoCal
Mach e, Explorer, Silverado
at quick glance, it looks like they added an EV data section to the My Journeys page.
edit: the EV data section also says "Trip Logs coming soon!".
Mirak
Kansas
Doesn’t look like this release makes any improvements to the stuff on my FP issue list….
  • Still nothing close to real-time car status updates. My car last updated its status 5hrs ago despite multiple forced refreshes, and restarting the app. Without real-time updates, makes it very hard to monitor active charging status for charges initiated through the app. Better off using third-party apps unless you’re trying to utilize free EA kWh.
  • Still no fix to distinguish between Plugs 1 and 2 on public chargers. Both plugs listed as one identical number, so you can’t tell which to initiate.
Ford Mustang Mach-E FordPass 3.21.0 Released B498B103-A38F-46F0-9E52-69363869C1A4
  • When I try to use app to modify my charging schedule or max charge, and I tap “save”, the app hangs on a “Loading” message. Then finally “Sorry, FordPass isn’t responding. Please try again later.
Ford Mustang Mach-E FordPass 3.21.0 Released 6F9B277E-DD3D-4A3C-8F17-D84D8D263FF9
Ford Mustang Mach-E FordPass 3.21.0 Released BABD47B9-1556-49D9-8C17-211B70643464
Until these issues are fixed, FordPass provides very little utility, and a whole lotta frustration.
Next the design issue: It makes no sense why under “Manage EV” there are sections for “Manage Charging” and “Charge Times”. The Charge Times page is already nested within “Manage Charging”. Redundant and confusing. Stupid design.
Ford Mustang Mach-E FordPass 3.21.0 Released E6DC9DC3-4D25-40A2-845D-5A2849536848
I’ve never really experimented with PAAK so that’s not on my list.
Shouldn’t we have a sticky thread to keep a running list of FordPass bugs? How do we make this more visible for the FordPass team?
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
This part was there in at least the last update on Android. I just updated the app today, but noticed the EV Data section there on Monday.
kirkus02
Kirk
SoCal
Best fix so far, it finally removed the "remote setup"
Sadly, mine is still there. :(
ah...didn't notice it before. I don't use my journeys, so, it just randomly stuck out as I was looking around.
@Mirak that's a nice list...i hope the FordPass is able to to address those.
jksu
LA
GT PE Shadow Black Night Pony
just downloaded it and seems to be a bit more responsive, switching screen to screen. otherwise, nothing else major... will see if PAAK works any better
Blue PonyE
Kirkland, Washington
2016 Leaf, 2021 First Edition, 2025 CRV Hybrid
Just saw this post and went to app store to update to 3.21.1 to see if that would let me set a departure time. So far no luck from app, able to set in vehicle. I get "Sorry Ford PASS isn't responding at this time. Please try again later."
Still not able to set a departure time.
The new version finally allows me to connect with my Fusion Energi but looks like has less functionality than the MyFord Mobile app. I’ll have to play with it to be sure though.
stangmatt21
Matt | macheauto
San Diego, CA
threads.net
'21 GTPE, '22 Lightning, VW R32, '66 Must Conv.
Digital Product Manager
This would take a complete paradigm shift of how the backend cloud service, car, and app work; not just a phone app update.
You don't initiate a plug, you initiate a charger. At EA, only 1 plug can be used on a charger at a time, it doesn't matter which one you plug into your car, other than speed (kW), which the app lists per plug. Touching "Select" selects the charger, not the plug.
Eraser
2021 Mach-E Premium RWD | SR
I haven't noticed any difference since the update. I haven't had much reason to go into the app as of late, and due to the sluggish performance and bugs I try to avoid opening the app at all.
Does anyone else find it strange that in both the Play Store and the App Store the app is rated 4+ of 5? In it's current state I'd have a hard time giving the app anything above a 2 of 5, for anyone to give it a 4+ is absurd IMO.
