Woeo
- Woeo
- Feb 2, 2020
- Maryland
- Woeo
- Fusion Energi
I feel sad for you.Switch the ball?
Gee, you can't even remember what you wrote. You probably should get that checked out. You are the one that insulted another member for being "Ill Informed" and You are the one that used residential heat pumps as an example. I responded to that example. Let me refresh your memory about what you wrote:
Where in your post did you write an air to air heat pump? You didn't. You're post included all heat pumps. BTW, tens of thousands of dollars??? Where did you pick up that number since you didn't even know about Geothermal? Do a little more googling after you read this thread. Perhaps some contractors charge that much, my buddy just paid about $12k.
As far as your statements being accurate, no they are not and you clearly don't understand heat pumps nor have you actually read this thread. If you understood heat pumps or read this thread you'd understand that a heat pump is just one component of a HVAC system. The mere fact that you talk about a heat pump drawing heat from the air proves you either haven't read the information here, or you can't comprehend it. There are other places to draw heat from when the air is too cold.
If you want to discuss HVAC intelligently, read the information here, watch the videos. If you simply want to make an uninformed rant, please continue as you are. Let me help you a little bit. A heat pump isn't an entire HVAC system. It is one part of that system. How the entire system is designed determines how effective and efficient it will be. Like a heat pump in a geothermal system is effective far below freezing, a properly designed HVAC system that includes a heat pump can be effective far below freezing. Read the thread, perhaps you'll learn something. Or do you think you know more about automotive manufacturing than one of the preeminent authorities in the field? You with what, zero knowledge and zero experience? Yeah, you're probably a lot more informed than Sandy Munro. Duh.
