ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
I'm using the windshid suction mount that was included with my DFR9. I have it pushed up to where the black dots are. The suction cups are as partially under the headliner to the edge of the glass. So far it's been working. I haven't ordered a universal visor mount yet. Thanks for reminding. me because I doubt the cups will hold up in cold weather. I'll order the universal mount tonight before I get sidetracked again.
Usually suctions cups work better in the cold because cold air causes the vacuum to increase. It’s summer heat that expands and breaks the vacuum. Assuming your seal is good…
roadshow
roadshow
Irondequoit, NY
2021 Ford. Mustang Mach-e Premium AWD
That hasn't been my experience. They don't hold up as well for me in winter. Then it's almost possible to reattach because the plastic becomes rigid.
roadshow
roadshow
Irondequoit, NY
Please let me know if you've figured this out yet. I was thinking the same thing; if we can get it into the headliner it would be perfect. I can't use the OEM suction cup mount because the angle doesn't allow the detector to lock in, so it just slides off when I accelerate..which is all the time. haha
I received the mount. It does. fit under the head liner, but it's. thin metal and has to be beefed up with.something like thin foam to keep it's secured in the head liner.
Tcoll
Tom
Belchertown MA
2021 mustang Mach e premium AWD 88kw
Respiratory therapist
I decided to venture and do this without any help or wiring diagrams. I couldn't find ANY resources online for any reference. I managed to figure it out and I took photos along the way to help others that may be wanting to do the same.
I've done many mirror taps in the past, but this one was a bit intimidating, not knowing where to tap because of all the unusually color coded wires, and all the tech involved in this piece.
PLEASE PLEASE be VERY careful removing the plastic housing. I don't want to be responsible for anyone breaking this piece. Be gentle and take your time.
Circled is the terminal that you will be using removing and tapping into. The release is on the top, towards the windshield.
Testing the taps:
The Black Wire is the neutral/ground. Connect the Black tap wire to this. The White Wire is the 12v switched lead. Connect the Red tap wire to this.
This is what it looks like tapped:
Testing:
Vehicle off:
Vehicle on:
Complete!
Thank you so much!! This worked like a charm. I used the blend mount kit.
sharkcom
Scott
Seattle, WA
Mustang Mach E GT
Testing the taps:
Testing:
Vehicle off:
Vehicle on:
Complete!
Could you tell me what specific Mirror Tap cable you used as I noticed there are different diameter sizes of the tap wire? Many thanks for the write up!
sharkcom
Scott
Seattle, WA
Mustang Mach E GT
Could anyone tell me what specific Mirror Tap cable you used as I noticed there are different diameter sizes of the tap wire? Thanks!
jdmrc93
jdmrc93
Allen Park, MI, USA
2021 Mustang Mach-E First Edition in Grabber Blue
IT Network Engineer
breeves002
St. Louis, MO
2021 Mach-E GT PE
Any idea if there's a circuit with constant voltage up there?
Pin 7 on the overhead console I think is constant 12v. VT/GY wire according to the diagrams.
Keep in mind small constant loads like a dash cam can mess up the BMS for the 12v battery.
GrumblesTheDog
2021 Mustang Mach-E GB FE
That's interesting - is that something unique to how you access 12V (ie tapping into an existing circuit in the mirror housing) or would that apply to any form of hardwiring? I don't doubt you, but it seems like you'd hear of more battery issues with dashcam users than you do.
breeves002
St. Louis, MO
2021 Mach-E GT PE
The BMS is bad about small loads on it when the car is off. It's like it goes to sleep or something. Then the battery SoC is lower than it thinks when you turn the car back on. I have heard of a lot of issues with this in various Fords. If the load is large enough it isn't an issue but really small trickle loads over days is what causes the most issues I think. @Mach-Lee should be able to elaborate. Or he'll tell me I'm completely wrong.
The BMS doesn't like it if the total idle power draw is more than 100 mA (including the idle module draw), otherwise it can't sense the battery's state properly. So if your radar detector or dash camera uses more than about 50 mA of power, then it needs to be on the switched 12V to avoid battery drain problems.
There have been a number of people with low 12V battery issues, I have to think at least of few of these are related to running 12V accessories without them realizing it.
Panzer948
Charlotte, N.C.
2023 MME GT PE, 2021 Ford Bronco, 2015 BMW M4, CJ5
Geologist
I have a Ford Bronco with dashcam using parking mode and have no issues running it. Blackview and other higher tier dash cam manufactures have auto cut off software that allows you to set the voltage the dash cam will cut off upon reaching said voltage. I have mine set to 11.8 volts, which takes a few days to reach. But never had any problems with restarting car. So wouldn't auto cut off dash cams be okay for MME?
Before auto cut off dash cams, some would get real fancy and add a second battery just to run the dash cam in parking mode. The dash cam companies made their on setups for this but the auto cut off feature has really eliminated the need for those unless an owner is parking his car for a very long period.
Back to my Bronco setup, my 900 Blackview series dash cam has its on wifi hotspot and can send alerts in real time to my phone (using cellular network) based on impacts, movement, etc. Just about as good as having a ring camera at your house. I felt that was worth it since the vehicle is a convertible. Not sure that need is as great on the Mach E though.
Darkenmage
Manny
Mach E GT AWDe and Honda Insight
Semi Retired
Testing the taps:
Testing:
Vehicle off:
Vehicle on:
Complete!
Awesome, exactly what I want to do with my Uniden R7.
TY.
Nemy
Portland, OR
2022 DMG Mach-E Premium X
I took my dash cam out when I sold my Select but I just used your post again to reinstall it. Thanks again OP!
