Mirak
- Oct 8, 2020
- Kansas
- "Sonic" 2021 MME Grabber Blue First Edition
With Powerup 2.3.0, @Ford Motor Company has now given us one more feature we requested - full screen Apple CarPlay!
After running the poll for nearly a month and 171 participants, here are the current standings. Many of these features at the top are consistent favorites after multiple rounds of polling. Some are likely much easier to implement than others.
I'll run this for a while longer before shutting it down. Eventually I'll start a new poll which puts the less popular requests out to pasture and adds the new suggestions. Please keep the votes and new suggestions coming.
One tap manual access to, or smarter automatic, front and 360 cams when parking | 48.5 |
Sentry Mode (but might not be possible with existing hardware?) | 47.4 |
Display detailed charging status on infotainment screen while public charging | 45 |
Ability to customize driver screen (move speedometer, see different data) | 42.7 |
Add option to replace heated seat slider with taps to toggle between Off 1 2 3 | 39.8 |
Use video apps on infotainment screen when parked | 37.4 |
Continued enhancement to DCFC charging curve (even better than 21P22) | 34.5 |
Ability to open frunk using FordPass | 33.3 |
Option to add an Instant Energy Use graphic to driver display like with Energi, Bolt, etc. | 33.3 |
Add vehicle health monitoring stats like battery temperature, motor temperature, etc. | 33.3 |
Make FordPass more responsive, cleaner, better organized, or just give EV owners their own app | 32.2 |
BlueCruise OTA Update | 31.6 |
Make volume knob multi-function to also adjust and slider functions such as fan speed and temp | 31 |
Make PAAK Much More Reliable (I dunno what else to say here - its still very spotty) | 29.8 |
Add automatic battery preconditioning for public chargers set in route plan | 26.9 |
Option to auto-tilt side mirrors when in reverse | 26.3 |
Portrait Mode Apple CarPlay / Android Auto - UPDATE, now available with 2.3.0 | 25.7 |
Allow cabin preconditioning to be set to specific temp | 25.1 |
Pet Mode | 23.4 |
One-tap from home screen to turn off HVAC | 22.8 |
Ability to set "safe zones" such as garage where auto-lock is disabled | 21.1 |
When plugging in at home, give pop up allowing easy way to manually override schedule and charge now | 21.1 |
Ability to keep HVAC in recirculation mode | 18.1 |
Add swipe-right shortcut bar to infotainment screen and ability to pin items there with long press | 12.9 |
Smarter Intelligent ACC to reduce speed before passing a lower speed limit sign | 12.9 |
Option to disable One Pedal Driving in reverse | 10.5 |
Ability to adjust propulsion sound volume | 8.8 |
Touch screen door opening (Uber mode) | 8.2 |
Allow dynamic expansion of battery, such as periodic “Charge to 110%" if conditions permit | 5.8 |
Customize default backup camera view (e.g. start up with the 3-way camera view) | 5.8 |
