- Jun 24, 2020
- Vermont
- 2024 Kia EV9 GT-Line
Unfortunately, no.Any chance one could charge the 12V battery with those leads...?
No. All this connection does is open the frunk. That's it.Any chance one could charge the 12V battery with those leads...?
Does the rear panel really need to be taken off too? I haven't touched them in mine yet but it seems like the + is the main one you need full access to under the side panel, and maybe the exposed - pole (which is just frame ground) might be accessible from there?If you can't get into the car, you'll have to connect a 12v power source to the leads in the little compartment in the front bumper. That will open the frunk, and from there you'll have to remove the rear and driver's side plastic panels to gain access to the 12v battery to jump start it.
From the reports I've read, you can't get the side panel off without removing the rear first. But I don't have my MME yet, so I can't confirm from personal experience.Does the rear panel really need to be taken off too?
No. Those leads only provide power to the front trunk release solenoid. Once inside the frunk you have to remove the rear trim piece (behind the storage compartment) and then the driver-side trim piece (The driver-side trim piece marks the + and - symbols indicating the position of the charging terminals.Any chance one could charge the 12V battery with those leads...?
Thank you to everyone who responded and helped (especially @TheVirtualTim) -- got the frunk open and it jump started successfully. Letting it sit there with power on (turned off the auto power-off at 30 minutes) -- I assume it will charge and keep charged the LVB at all times when the car is turned on (otherwise it wouldn't really be able to support those dual 20A 12V sockets, you'd run through the LVB real quick).No. Those leads only provide power to the front trunk release solenoid. Once inside the frunk you have to remove the rear trim piece (behind the storage compartment) and then the driver-side trim piece (The driver-side trim piece marks the + and - symbols indicating the position of the charging terminals.
The trim panels are press-fit (they basically "snap" in) vertically ... lift straight-up to pop them out (Don't pull sideways).
If and when this happens, if you unplug the mme, would the hvb eventually charge the 12v? Or no bc it needs 12v to open the dc-dc?No. Those leads only provide power to the front trunk release solenoid. Once inside the frunk you have to remove the rear trim piece (behind the storage compartment) and then the driver-side trim piece (The driver-side trim piece marks the + and - symbols indicating the position of the charging terminals.
The low-voltage battery is a 35 amp hour AGM battery. Use an AGM battery charger to charge it ... ideally something that can supply about 10 amps or more. I used a trickle charger that could only supply 4 amps and it really wasn't enough (the car was trying to wake up but didn't have enough power). I switched to a 10 amp charger and it was happy.
Once the software update was applied to my car it's been happy ever since.
If you aren't able to get it over to a dealer right away then leave the car unplugged when not actively charging and you wont have a recurrence of a low 12v battery. (But do get it fixed via software update).
It depends on how low the 12v battery is drained. The module that monitors the state of charge on the 12v battery is using that same 12v battery to run the module. (Fun fact ... the module that handles OTA updates *also* runs on the 12v battery. So you wouldn't be able to do an OTA until the low-voltage battery is charged.) So if the 12v battery is TOO low, it wont even have enough power to monitor itself correctly and start a charge (you'd have to put a 12v AGM battery charger on it to bring up the state of charge). But if it has enough power it will pull power from the HVB to bring up the charge on the 12v. This works correctly when the car is not plugged in ... even on a car that needs the software update.If and when this happens, if you unplug the mme, would the hvb eventually charge the 12v? Or no bc it needs 12v to open the dc-dc?
glad you figured out Frunk jump...Thank you to everyone who responded and helped (especially @TheVirtualTim) -- got the frunk open and it jump started successfully. Letting it sit there with power on (turned off the auto power-off at 30 minutes) -- I assume it will charge and keep charged the LVB at all times when the car is turned on (otherwise it wouldn't really be able to support those dual 20A 12V sockets, you'd run through the LVB real quick).
I've had less luck getting a Ford dealership (all of whom are selling the ME but claim they don't know how to service it) to be receptive to updating the software. Got one to agree to take it with the condition that it may be several days or "a while" before I get it back. Will push them to call the Zone Rep to get access to the necessary software update since it's not tied to the VIN.
In my experience, it will, depending on how low the 12v has dropped.If and when this happens, if you unplug the mme, would the hvb eventually charge the 12v? Or no bc it needs 12v to open the dc-dc?
My MME came five days ago and the dealer swore up and down that there were no updates or service bulletins tied to my VIN. So either they didn't bother and lied to me, or (as others have suggested in this thread) this is not an update that is tied to VINs, at least right now. Or, if they really do need to specifically request access to some of the software updates, maybe it doesn't show up until they actually have access to apply it.rumor is that Dealers *should* be able to verify updates by VIN in a system they call OASIS or some such... but there is no direct way that Owners can tell which fixes have been applied... there are no 'release notes' for major releases or bug fix updates that I am aware of.... but it sure would be nice if we could get an email/newsletter/report by VIN, perhaps in our Ford.com account, showing what version our vehicle is at, and release notes for each update?!
Did anyone ever confirm (or at least find support) that this TSB is actually for the LVB drain issue? I'm not doubting you at all, it just feels like the speculation surrounding the stop ship/QC holds earlier this month...some educated guesses, but no hard evidence either way (which I assume we'll never get
